Hey i want to build a pc but i am not sure on what the best parts are within my budget so any help would be much appreciated. I have a budget of $2200 AUD which is around $1500 USD i am willing to go a bit over budget if needed. The main purpose of this pc is to play some of the high demanding games on it like battlefield,forza,gta ect.
Thanks for the help
https://linustechtips.com/topic/1156258-help-me-build-pc/
Do you need a monitor/peripherals?
If you already have a monitor, what refresh rate/resolution is it?
https://linustechtips.com/topic/1156258-help-me-build-pc/#findComment-13301280
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1156258-help-me-build-pc/#findComment-13301283
i currently have a 27" 144hz 1920x1080 monitor. i want to get a second monitor but it doesnt need to come from the budget stated before as i will  get it at a later date when i have saved up some more money.
https://linustechtips.com/topic/1156258-help-me-build-pc/#findComment-13301351
something like this :
PCPartPicker Part List
CPU: AMD Ryzen 5 3600X 3.8 GHz 6-Core Processor  ($328.00 @ Shopping Express)
CPU Cooler: Deepcool GAMMAXX GT 29.5 CFM CPU Cooler  ($45.00 @ PCCaseGear)
Motherboard: MSI B450-A PRO MAX ATX AM4 Motherboard  ($149.00 @ Centre Com)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3000 Memory  ($118.38 @ Amazon Australia)
Storage: Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive  ($77.00 @ Shopping Express)
Video Card: XFX Radeon RX 5700 XT 8 GB THICC III Ultra Video Card  ($669.00 @ PCCaseGear)
Case: Deepcool E-Shield ATX Mid Tower Case  ($49.00 @ BudgetPC)
Power Supply: Cooler Master MWE Bronze V2 550 W 80+ Bronze Certified ATX Power Supply  ($79.00 @ PCCaseGear)
Monitor: Asus TUF Gaming VG27AQ 27.0" 2560x1440 165 Hz Monitor  ($689.00 @ PCCaseGear)
Total: $2203.38
Generated by PCPartPicker 2020-02-17 11:09 AEDT+1100
https://linustechtips.com/topic/1156258-help-me-build-pc/#findComment-13301373
Then in that case what @Fasauceome is good.
you could take the GPU down to a 5700 XT or 2070 Super to fit in another display
https://linustechtips.com/topic/1156258-help-me-build-pc/#findComment-13301381
CPU: AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor  ($464.00 @ Shopping Express)
Memory: Patriot Viper 4 Blackout 16 GB (2 x 8 GB) DDR4-3200 Memory  ($103.00 @ Amazon Australia)
Storage: Pioneer 512 GB M.2-2280 NVME Solid State Drive  ($105.19 @ Amazon Australia)
Video Card: Inno3D GeForce RTX 2080 SUPER 8 GB Twin X2 OC Video Card  ($1089.00 @ JW Computers)
Case: Cooler Master MasterBox NR600 (w/o ODD) ATX Mid Tower Case  ($89.00 @ Umart)
Power Supply: Corsair TXM Gold 550 W 80+ Gold Certified Semi-modular ATX Power Supply  ($119.00 @ Austin Computers)
Total: $2195.19
Generated by PCPartPicker 2020-02-17 13:47 AEDT+1100
if you rather have the monitor now:
Video Card: Gigabyte Radeon RX 5700 XT 8 GB GAMING OC Video Card  ($639.00 @ PLE Computers)
Monitor: ViewSonic VX2758-2KP-MHD 27.0" 2560x1440 144 Hz Monitor  ($409.00 @ Scorptec)
Total: $2154.19
Generated by PCPartPicker 2020-02-17 13:49 AEDT+1100
https://linustechtips.com/topic/1156258-help-me-build-pc/#findComment-13301643
