Does anyone know of a program that will monitor your GPU temps and stop mining or shut down your pc if you go over a certain temp?
Build 1: 4770k (H100i) | 2 x MSI 280X Gaming 3G | Asus ROG Maximus VI Hero | Corsair RM850 | 16GB Corsiar Vengeance 1600MHz | Corsair Obsidian 750D |
Build 2: 3770k (Titan Fenrir Evo) | Powercool 3GB HD7970 Asus Sabertooth Z77 | Corsair TX750 | 16GB Kingston HyperX Genesis 2133MHz Inwin Fanqua |
https://linustechtips.com/topic/115605-auto-shutdown/
in sgminer you can do --temp-cutoff 75
|Casual Rig| CPU: i5-6600k |MoBo: ROG Gene  |GPU: Asus 670 Direct CU2 |RAM: RipJaws 2400MHz 2x8GB DDR4 |Heatsink: H100i |Boot Drive: Samsung Evo SSD 240GB|Chassis:BitFenix Prodigy |Peripherals| Keyboard:DasKeyboard, Cherry MX Blue Switches,|Mouse: Corsair M40
|Server Specs| CPU: i7-3770k [OC'd @ 4.1GHz] |MoBo: Sabertooth Z77 |RAM: Corsair Vengeance 1600MHz 2x8GB |Boot Drive: Samsung 840 SSD 128GB|Storage Drive: 4 WD 3TB Red Drives Raid 5 |Chassis:Corsair 600t
https://linustechtips.com/topic/115605-auto-shutdown/#findComment-1545674
I have done but it still sometimes goes over.
https://linustechtips.com/topic/115605-auto-shutdown/#findComment-1545682
I use Corsair Link software with my 660tis and H100i that allows me to auto turn off pc when hits a certain degree in settings. I dont think you need a corsair product for it to work.
http://www.corsair.com/us/corsair-link-techzone/
CPU: Intel i5 3570k @4200 | Motherboard: ASUS P8Z77-V LK | RAM: 8gb Crucial Ballistix @1600 | GPU: Evga GTX 660 TI x2 SLI | Case: Corsair C70 | Storage: WD Black 1TB, Samsung 830 126GB SSD, Kingston V300 120GB SSD | PSU: Corsair HX850 | Display(s): ASUS 2ms 24inch 1920x1080 | Cooling: Corsair H100i | Keyboard: Razer BlackWidow Ultimate 13 | Mouse: Razer Naga 13
https://linustechtips.com/topic/115605-auto-shutdown/#findComment-1545714
The default BIOS temperature hysteresis is 6 degrees Celsius so you need to set your temperature cutoff to be lower than your limit.
So if i wanted it to stop at 90 degrees i should set it to 84?
https://linustechtips.com/topic/115605-auto-shutdown/#findComment-1545814
