Hello to everyone
6 months ago i bought a brand new QNAP TS-431P , and 4 WD 8 TB each (Nasware FFBX)
Everything was working perfectly but one day , as i started my nas, i discovered that is not accessable, either by internet browser, either by qnap pro app
I tried to another switch, router, pc, but nothing(also changed all the Lan cables).
I left and tried again after 2 days but also nothing happened.
The point to me, is that in these disks , is everything for me. my job, me life, photos etc.
Please help, in any way
I have to mention that nas, is starting normally, with status led green, Lan status orange and disks all green.
Thank you
IF there is a solution, plugging these disks to Pc or another nas WITHOUT losing data, could be very helpfull
https://linustechtips.com/topic/1156006-problem-with-my-nas-please-help/
The quickest, easiest solution would be to just buy another QNAP TS-431P and putting those drives in it.
Sounds like a firmware update just derped.
If you haven't tried a config reset (won't touch data on the disks) I would advise you to check this article from qnap.
That's exactly why I prefer buying old server gear than locked down boxes. More use to them for the same price, and you have full control over it, and no dirty surprises like that.
I'd check out their Knowledge base, in particular this article. https://www.qnap.com/en/how-to/knowledge-base/article/my-nas-cant-be-powered-on-or-it-does-not-boot-how-to-fix-it/
I presume its most likely either Problem #2 or #3
If you still can't resolve it, given its only 6 months old, its well within support. You should open a ticket with QNAP if you're unsure https://www.qnap.com/en/support-ticket/
They may need to RMA it for you, they should ask you to take out the disks and RMA it...always best to label which drive bay they go in.
Desktop: Ryzen9 5950X | ASUS ROG Crosshair VIII Hero (Wifi) | EVGA RTX 3080Ti FTW3 | 32GB (2x16GB) Corsair Dominator Platinum RGB Pro 3600Mhz | EKWB EK-AIO 360D-RGB | EKWB EK-Vardar RGB Fans | 1TB Samsung 980 Pro, 4TB Samsung 980 Pro | Corsair 5000D Airflow | Corsair HX850 Platinum PSU | Asus ROG 42" OLED PG42UQ + LG 32" 32GK850G Monitor | Roccat Vulcan TKL Pro Keyboard | Logitech G Pro X Superlight  | MicroLab Solo 7C Speakers | Audio-Technica ATH-M50xBT2 LE Headphones | TC-Helicon GoXLR | Audio-Technica AT2035 | LTT Desk Mat | XBOX-X Controller | Windows 11 Pro
Server: Fractal Design Define R6 | Ryzen 3950x | ASRock X570 Taichi | Asus RTX 4060 Dual OC | 64GB (4x16GB) Corsair Vengeance LPX 3000Mhz | Corsair RM850v2 PSU | Fractal S36 Triple AIO + 4 Additional Venturi 120mm Fans | 8 x 20TB Seagate Exos X22 | 4 x 16TB Seagate Exos X18 | 3 x 2TB Samsung 970 Evo Plus NVMe | LSI 9211-8i HBA
NAS: Innovision 4U 24-bay chassis (12GB MiniHD SGIO Backplane) | Intel Core i9-10980xe | EVGA X299 FTW-K | EVGA RTX 2080Ti Super FTW3 | 128GB (8x16GB) Corsair Vengeance LPX 3200Mhz | DEEPCOOL PN1000M PSU| Noctua NH-D12L Chromax Black | 16 x 16TB Seagate Exos X18 | 2 x 2TB Samsung 990 Pro | 2 x 2TB Intel U.2 P4510 | LSI 9305-24i HBA
