1 minute ago, Brokenquasar637 said:
It has no display and fans do not spin but when I unplug the 6 pin connectors the fans spin up yet still no display
Without the 6 pin plug in, it won't do anything. That is normal.
What GPU is it? What are your specs?
Are you plugging the monitor into the video cards output and not the motherboards? We need more info.
Yes, we need more info.
  • 2 weeks later...
