I am very Computer savvy but can not get my head around audio at all!!
I want to get the most out of my nice headphones but feel i might not be with my on board audio chip.
i am currently using Sennheiser x Massdrop HD 6xx headphones.
any help out be awesome, I use these for editing, Gaming, and just music while i work.
https://linustechtips.com/topic/1154955-i-need-some-audio-help/
A bit of a complicated step would be as follows.
Right Click the Volume icon on your takbar > select "Open Sound Settings" > Right Click your correct output > Select "Properties" > "Advanced" And ensure "Default Format" is on the highest setting.
If you are using a specific brand PC (Such as ASUS) it may have an audio manager such as "Realtek" that auto detects your headphones. You could play with EQ settings in there to ensure a sound stage you like.
Other than that I can no longer offer guidance. I am not an Audiophile and have no trained ear so my basic headsets work fine for me. Sorry and hope it helps a little.
i7-6700k OC'd 4.5Ghz, Noctua NH-D15, EVGA GEFORCE GTX 1070 SC
https://linustechtips.com/topic/1154955-i-need-some-audio-help/#findComment-13291858
