Hey Everyone,
So i have a GTX 780 Ti and when play Battlefield 4 on high/ultra settings my GPU runs really hot aoubt 75-83 celcius. So im going to water cool it, not the actual water the gel type of stuff. So im thinking of getting a NZXT Kraken G10 and a probably a Corsair H90, what one do you guys think should i water cool my 780 ti?
Thanks Guys :)
NZXT Kraken G10: https://www.nzxt.com/product/detail/138-kraken-g10-gpu-bracket.html
Corsair H90: http://www.corsair.com/en/cpu-cooling-kits/hydro-series-water-cooling-cpu-cooler/hydro-series-h90-140mm-high-performance-liquid-cpu-cooler.html
*EDIT*
CPU: i5 4670k @ 3.4 Ghz MOBO: Asus Z87 Sabertooth RAM: Corsair Vengeance 2 x 4gb @ 1866Mhz GPU: GTX 780 Ti Case: Corsair 750D HDD: Kingston 120gb, WD 500GB & WD 1tb PSU: Corsair Rm 750w with Blue Sleeved Cables Monitors: Acer 24", Acer 21", Samsung 18" CPU Cooling: Cooler Master Seidon 120M Keyboard: Roccat Ryos MK Pro Mouse: Razer Death Adder Speakers: Edifer 5.1 Surround Sound Microphone: Blue Yeti
PcPartPicker: http://pcpartpicker.com/user/LozzaNewport/saved/4dT0
https://linustechtips.com/topic/115441-water-cooling-graphics-card/
Hey Everyone,
So i have a GTX 780 Ti and when play Battlefield 4 on high/ultra settings my GPU runs really hot aoubt 75-83 celcius. So im going to water cool it, not the actual water the gel type of stuff. So im thinking of getting a NZXT Kraken G10 and a probably a Corsair H90 or H80i, what one do you guys think is better and should i water cool my 780 ti?
Thanks Guys :)
Corsair H80i: http://www.corsair.com/en/cpu-cooling-kits/hydro-series-water-cooling-cpu-cooler/hydro-series-h80i-high-performance-liquid-cpu-cooler.html
The H80 Is Not On the compatibility list but the H90 is so....
Christian and Proud of it
Please read the CoC        My Build Log
woops ty :)
Why watercool?
Why watercool?
cause the 780 ti is hot and i would prefer it to be cooler, plus i'd be able to overclock :D
Edit your fan curve, unless you desperately want to use an AIO.
Corsair 400C- Intel i7 6700- Gigabyte Gaming 6- GTX 1080 Founders Ed. - Intel 530 120GB + 2xWD 1TB + Adata 610 256GB- 16GB 2400MHz G.Skill- Evga G2 650 PSU- Corsair H110- ASUS PB278Q- Dell u2412m- Logitech G710+ - Logitech g700 - Sennheiser PC350 SE/598se
Is it just me or is Grammar slowly becoming extinct on LTT?
The gpu raises it's clock speed until it hits 80c. That's how it works.
Those temps are pretty normal for GPUs
i no, but id like to make it cooler plus oc it a bit
Gel type of stuff?
My Personal Rig - AMD 3970X | ASUS sTRX4-Pro | RTX 2080 Super | 64GB Corsair Vengeance Pro RGB DDR4 | CoolerMaster H500P Mesh
My Wife's Rig - AMD 3900X | MSI B450I Gaming | 5500 XT 4GB | 32GB Corsair Vengeance LPX DDR4-3200 | Silverstone SG13 White
Gel type of stuff?
yea, the water loop, which is water, then the water coolers which has a gel type like inside
No they don't? I think you're confused, gel won't flow due to its viscocity.
Water coolers have...water inside. Not gel, they are water cooleras, not gel coolers.
Hey Everyone,
Thanks Guys :)
*EDIT*
Are you sure its not because they ship it with a custom fan curve with GPU boost 2.0 set to 80 Celsius?
edit: looks like @WoodenMarker beat me to it :P
