I just finished my first ever build. I had a low budget so the specs aren't the best but I'm happy with it. I purchased a refurbished dell inspiron with an Intel i5 4460, 8GB of DDR3 RAM at 1600MHZ, and a 500GB HDD. I then upgraded to an Antec High Current Gamer 400W 80+ Bronze PSU (a craigslist find for $25 USD new in the sealed original packaging). Lastly I got a Zotac GTX 1060 6GB Mini on Ebay for slightly over $100 USD. Let me know what you think of the parts I chose and what upgrade paths you think I should take in the future. Thank you.
https://linustechtips.com/topic/1153962-my-first-build/
It will game, but some pictures of the build would be nice. A good build is a little more than the specs of the parts inside.
Gaming With a 4:3 CRT
System specs below
CPU: AMD Ryzen 7 5700X with a Noctua NH-U9S cooler
Motherboard: Gigabyte B450 Aorus M (Because it was cheap)
RAM: 32GB (4 x 8GB) Corsair Vengance LPX 3200Mhz CL16
GPU: EVGA GTX 980 Ti SC Blower Card
HDD: 7200RPM TOSHIBA DT01ACA100 1TB, External HDD: 5400RPM 2TB WD My Passport
SSD: 1tb Samsung 970 evo m.2 nvme
PSU: Corsair CX650M
Displays: ViewSonic VA2012WB LCD 1680x1050p @ 75Hz
Gateway VX920 CRT: 1600x1200@75Hz, 1200x900@100Hz, 960x720@125Hz, 800x600@140Hz
Gateway VX900 CRT: 1600x1200@75Hz, 1200x900@100Hz, 960x720@120Hz (Can be pushed to 175Hz)
Keyboard: Thermaltake eSPORTS MEKA PRO with Cherry MX Red switches
https://linustechtips.com/topic/1153962-my-first-build/#findComment-13288905
