Need help if anyone has encouter this problem
Hi i recently added 2 new parts to an old build i added a b450 tomahawk max and ryzen 3600
everything appears to work fine but when i power up the computer the first time the pc will post , then when it is time to show me the loading screen the display turns off. When i shut it down and restart it  again it does work fine , but when i shut it down again and  turn it on the same problem appears. Does anyone have a solution?
i already  check the ram i try different power supply i remounted motherboard i check all the mounts recheck cables..
current build
b450 tomahawk
Ryzen 3600
Nzxt kraken x62
Parts from old build
Evga 850 Gold
Evga Gtx 1070
1tb ssd
Corsair Led DDR4 3000mhz
