Blue Snowball, Blue Yeti.
EDIT: Doesn't electric guitar have output?
https://linustechtips.com/topic/115295-microphone-for-recording/#findComment-1541132
I consider anything sub-$100 USD that sounds good a good value:
Blue Snowball, Yeti, AT 2020 (USB or XLR), AT 2500 (I have it :D ), MXL 770 (XLR mic that you can get for $69 on amazon and a decent converter can bring you up to maybe $110), Nessie.
Current System: CPU - I5-6500 | Motherboard - ASRock H170M-ITX/ac | RAM - Mushkin Blackline 16GB DDR4 @ 2400mHz | GPU - EVGA 1060 3GB | Case - Fractal Design Nano S | Storage - 250GB 850 EVO, 3TB Barracuda | PSU - EVGA 450W 80+ Bronze | Display - AOC 22" 1080p IPS | Cooling - Phanteks PH-TC12DX_BK | Keyboard - Cooler Master QuickFire Rapid(MX Blues) | Mouse - Logitech G602 | Sound - Schiit Stack | Operating System - Windows 10
The OG System: I3-2370M @ 2.4 GHz, 750GB 5400 RPM HDD, 8GB RAM @1333Mhz, Lenovo Z580 Laptop (Ubuntu 16.04 LTS).
Peripherals: G602, AKG 240, Sennheiser HD 6XX, Audio-Technica 2500, Oneplus 5T, Odroid C2(NAS).
https://linustechtips.com/topic/115295-microphone-for-recording/#findComment-1541135
It does but I want the sound of the speaker aswell. Pus there is less interference.
Budget? In theory you could get an SM57 and a half decent interface which will pretty much have you set for everything you want to do. I have an Audio Technica AT2020 and an SM57 and I would be happy to send you sound samples of both guitar and vocals
Feel free to message me if you want to chat!
https://linustechtips.com/topic/115295-microphone-for-recording/#findComment-1541174
Samson Meteor has worked well for me.
System: 5930K, MSI X99 SLI PLUS, GTX 780Ti (SLI),  840 EVO, Fractal R4 (Full Custom Loop)  (IP)
Media Server/Perm Folder: i3 4130, CX500, 4 X WD Red 1TB, 60GB Adata SSD for boot, Node 304, ASrock Z87-E ITX, 8GB Kingston Value Ram
https://linustechtips.com/topic/115295-microphone-for-recording/#findComment-1541194
It does, but you play guitar with an amp. He'll have to spend money on a DAW/amp modelling software with this route. Better to just mic up the amp
https://linustechtips.com/topic/115295-microphone-for-recording/#findComment-1541244
