Right so I've been trying to upgrade my PSU so I can upgrade my GPU. My system runs fine with my 500w evga PSU but when I've tried 750w PSUs (Corsair RM750x, evga 750 GQ) I've run into issues with my pc:
-The Corsair turns on fine but holds the fans and lights on in my system after I turn it off.
-The evga won't get past a brief fan spin and the lights blink on.
I'm at my wit's end trying to figure out why my system won't work properly so any advice is much appreciated. Thanks in advance!
System specs:
i7-7700k
Asus prime b250 - plus
Trident Z RGB DDR4-3200 2x8gb
WD Black PCIe gen3x4 NVMe
No GPU for testing
Previously mentioned PSUs
https://linustechtips.com/topic/1152831-power-supply-issues/
