I just bought a new AC750 Wireless Dual Band Router, Archer C20, but after I set it up, the speed that gives me on both WI-FI and on ethernet cable is really low. I set it up flowing step by step the instructions to configure it in router mode but it gives me a maximum speed of 8Mbps while if I connect my pc directly to the same cable with which I connect the router to the modem, it gives me a minimum speed of 60Mbps.
I already try to restart both the router and the modem, try to restore the router and start over and even try to update the router's firmware with the file I downloaded from "this page" but nothing.
I don't know what to do anymore, I need help.
Router specs:
Brand: TP-Link
Model: Archer C20
Hardware Version: V5
Firmware version: 0.9.1 4.16 v0001.0 Build 190103 Rel.45825n (4553)
Thanks in advance.
https://linustechtips.com/topic/1152797-slow-internent-speed/
What speeds do you currently pay your ISP for
Optical Drive Poll: https://linustechtips.com/main/topic/1006309-optical-drive-survey/
Main Rig (Redshift)
CPU: Ryzen 7 9800X3DX MOBO: MSI MAG X870E Tomahawk WIFI RAM: G.Skill Flare X5 (2x16gb) 6000MT/s 28-36-36-96 GPU: Sapphire NITRO+ 9070XT, Cooler: Noctua NH-D15 Chromax Storage:  Intel S3520 150gb x4 RAID0 for boot, Crucial P310 4tb x2 RAID0, MSI Spatium M470 1tb, SK Hynix Platinum P41 2tb,  Case: Phanteks Evolv X2 PSU: Seasonic Foucs GX 850W OS: Windows 11 Pro 64 bit
HexOS Server (Vault)
CPU: Xeon E5-2603v3 MOBO: MSI X99 Tomahawk RAM: G.Skill Aegis (4x8gb) 3000MT/s 16-18-18-38 GPU: Headless Cooler: Cooler Master Hyper 212 LED Storage: Intel S3520 150gb x2 for boot RAID1, x16 in RAIDZ1 for storage, LSI 9305-16i HBA,  Case: Phanteks Enthoo Pro Tempered Glass PSU: EVGA SupeNOVA G1+ 750W
https://linustechtips.com/topic/1152797-slow-internent-speed/#findComment-13275327
What are you using for speedtesting? If speedtest.net, are you using the same server each time?
And to be clear, a quite popular thing is to get units confused - Are we talking MB/s (megabytes per second) or Mb/s aka Mbps (megabits per second) here? That's an 8 times difference.
HAL9000: AMD Ryzen 9 3900x | Noctua NH-D15 chromax.black | 32 GB Corsair Vengeance LPX DDR4 3200 MHz | Asus X570 Prime Pro | ASUS TUF 3080 Ti | 1 TB Samsung 970 Evo Plus + 1 TB Crucial MX500 + 6 TB WD RED | Corsair HX1000 | be quiet Pure Base 500DX | LG 34UM95 34" 3440x1440
Hydrogen server: Intel i3-10100 | Cryorig M9i | 64 GB Crucial Ballistix 3200MHz DDR4 | Gigabyte B560M-DS3H | 33 TB of storage | Fractal Design Define R5 | unRAID 6.9.2
Carbon server: Fujitsu PRIMERGY RX100 S7p | Xeon E3-1230 v2 | 16 GB DDR3 ECC | 60 GB Corsair SSD & 250 GB Samsung 850 Pro | Intel i340-T4 | ESXi 6.5.1
Big Mac cluster: 2x Raspberry Pi 2 Model B | 1x Raspberry Pi 3 Model B | 2x Raspberry Pi 3 Model B+
https://linustechtips.com/topic/1152797-slow-internent-speed/#findComment-13275361
1.- I do use speedtest.net
2.- No, I am not using the same server each time
3.- Sorry, I meant Mbps
https://linustechtips.com/topic/1152797-slow-internent-speed/#findComment-13275374
