Hello All,
Was wondering how to separate Wi-Fi into separate VLANs, sort of like how with most home routers there is a guest SSID with only internet access. Are you able to create multiple "Wi-Fi VLANs"
I currently have a Netgear r6400 and a managed switch able to create VLANs.
Thanks
https://linustechtips.com/topic/1152390-vlans-on-wireless/
The simplest thing to do is to get another WAP, run it to the switch, and make sure that port is on a different VLAN.
Editing Rig: Mac Pro 7,1
System Specs: 3.2GHz 16-core Xeon | 96GB ECC DDR4 | AMD Radeon Pro W6800X Duo | Lots of SSD and NVMe storage |
Audio: Universal Audio Apollo Thunderbolt-3 Interface |
Displays: 3 x LG 32UL950-W displays |
Gaming Rig: PC
System Specs:  Asus ROG Crosshair X670E Extreme | AMD 7800X3D | 64GB G.Skill Trident Z5 NEO 6000MHz RAM | NVidia 4090 FE card (OC'd) | Corsair AX1500i power supply | CaseLabs Magnum THW10 case (RIP CaseLabs ) |
Audio:  Sound Blaster AE-9 card | Mackie DL32R Mixer | Sennheiser HDV820 amp | Sennheiser HD820 phones | Rode Broadcaster mic |
Display: Asus PG32UQX 4K/144Hz displayBenQ EW3280U display
Cooling:  2 x EK 140 Revo D5 Pump/Res | EK Quantum Magnitude CPU block | EK 4090FE waterblock | AlphaCool 480mm x 60mm rad | AlphaCool 560mm x 60mm rad | 13 x Noctua 120mm fans | 8 x Noctua 140mm fans | 2 x Aquaero 6XT fan controllers |
https://linustechtips.com/topic/1152390-vlans-on-wireless/#findComment-13272455
7 hours ago, energycl01 said:
Hello All,
Thanks
You can, but I doubt the Netgear itself supports VLANs. That's not necessarily a problem, it just means you'll need to do a bit extra config and you might require an additional Access point.
Basically, the proper way to do it would be as follows:
Modem -> Router -> Managed Switch -> Port w/ VLAN -> AP (or Router w/ routing features disabled)
Basically you want the AP (or the wireless router) to run on a port that's being fed from a specific VLAN.
Here's the downside: If your Router/AP doesn't have native VLAN support, you'll need a separate physical AP for each separate "WIFI VLAN" you want to run. If you are okay with all WIFI traffic being on one VLAN, then that simplifies things.
For Sale: Meraki Bundle
iPhone Xr 128 GB Product Red - HP Spectre x360 13" (i5 - 8 GB RAM - 256 GB SSD) - HP ZBook 15v G5 15" (i7-8850H - 16 GB RAM - 512 GB SSD - NVIDIA Quadro P600)
https://linustechtips.com/topic/1152390-vlans-on-wireless/#findComment-13272825
A lot of consumer devices now automatically support a segregated guest SSID.
Otherwise it's typically done on a SSID to VLAN mapping and would depend on the settings available on your equipment, tagging VLAN to SSID is usually outside of the consumer space.
PC : 3600 · Crosshair VI WiFi · 2x16GB RGB 3200 · 1080Ti SC2 · 1TB WD SN750 · EVGA 1600G2 · Define C
https://linustechtips.com/topic/1152390-vlans-on-wireless/#findComment-13272893
9 hours ago, energycl01 said:
Hello All,
Thanks
Instruction Manual page 120
https://linustechtips.com/topic/1152390-vlans-on-wireless/#findComment-13273430
