Hi,
I am looking to upgrade my RAM as I am purchasing a new Z390 motherboard and an i7 9700kf.
My current RAM is the G.Skill Trident Z RGB at 2400mhz 16gb. I'm wondering what would be the best option for maximum FPS while gaming.  I play competitive games like Overwatch and I play on all low settings for max frames. What would be the best RAM to get? I was looking at Dominator Platinum RGB at 3200mhz because it overclocks well. Is 3200mhz as good as it gets for gaming, or will 4000, 4800 etc be even better?
Thanks!
MY RIG
MOBO: ASUS Prime B250M-A
CPU: Intel Core i5 6400
GPU: Galax GTX 1080 EXOC SNIPER White RGB
RAM: Corsair vengeance 16GB DDR4
PSU: Corsair VS650 650W
SSD: Seagate 128gb ssd
HDD(s): Barracuda 500gb HDD + Barracuda 1TB HDD
https://linustechtips.com/topic/1152198-help-with-ram-upgrade/
Considering the rest of your system specs I think buying 3200Mhz Dominator Platinum RAM is a waste of money, get a 16GB kit of whatever is cheap and good for 3200MHz, you are reaching past the point of diminishing returns if you spend $40+ on RAM that is effectively going to run the same. Better off saving that money to upgrade your CPU + Mobo in the future.
This will suffice:
https://pcpartpicker.com/product/p6RFf7/corsair-memory-cmk16gx4m2b3200c16
AMD Motherboard Tier List  GPU Cooling Tier List  PSU Tier List  A Dive Into Custom Keyboards & Mechanical Switches
NEWCOMERS Remember to ' Reply ' to comments in order for people to see them, this is done by clicking the arrow icon at the bottom of a comment (Quote).
My Builds:
MEGA Desk Build
Blueberry Pi  R9 3950X  Asus X470 ROG Crosshair VII Hero Wi-Fi ATX  Corsair Vengeance RGB Pro 4x16GB 3200MHz CL16  EVGA GTX 1080Ti SC Black Edition 11GB  EVGA P2 850W w/ Blue Sleeved Cables  Cryorig R1 Universal (Blue)  2x Corsair Force MP510 4TB w/ Asus Hyper m.2 V2  Corsair ML Pro Blue LED Fans  Fractal Design Meshify C TG ATX Mid Tower
Asus ROG SWIFT PG348Q 100Hz IPS G-Sync UW  Dell UltraSharp U3419W 60Hz IPS UW  Custom TOFU96  Corsair Scimitar Pro RGB
Work Rig  ThreadRipper 3970X  Asus Prime TRX40 Pro ATX  G.Skill RipjawsV 8x32GB 3200Mhz CL16  Nvidia Quadro RTX 6000 24GB  Corsair HXi 1000W  EVGA CLC 360 AIO  8x Sabrent Rocket 2TB w/ 2x Asus Hyper m.2 V2   Arctic P12 Fans  Phanteks P400A ATX Mid Tower
Plotting Machine 1  ThreadRipper 2990WX  AsRock X399 Taichi ATX  Kingston HyperX Fury 8x16GB 2666Mhz CL18   Nvidia Quadro K600 1GB  Corsair RMx 850W  EVGA CLC 360 AIO ‖ 2x Sabrent Rocket 2TB & 2x Sabrent Rocket 4TB w/ Asus Hyper m.2 V2  Arctic P12 Fans  Rosewill RSV-L4500 4U  5x Dell DS60 60-bay JBOD w/ 1.2PB of HDD Storage  HP 22U Half Rack
Plotting Machine 2  R9 3950X  Asus TUF X570-Plus Wi-Fi ATX  G.Skill RipjawsV 4x16GB 3200Mhz CL16   Nvidia Quadro K600 1GB  Corsair RM 650W  Noctua NH-D15s Chormax ‖ 4x Corsair MP600 Force 1TB W/ Asus Hyper m.2 Gen4  Arctic P14 & P12 Fans  Silverstone FARA R1 ATX Mid Tower
J.A.R.V.I.S.  R9 3900XT  Asus B550-I ROG STRIX Wi-Fi ITX  G.Skill Ripjaws V 2x16GB 3600MHz CL16  EVGA GTX 1080 SC2 iCX 8GB  Corsair SF 750W Platinum  Corsair H100i Pro AIO  Noctua NF-A12x15 Chromax Fans  FormD T1 SFF ITX Case
LG 75UM8070PUA 4K UHD 120Hz IPS HDR TV  Corsair K63 Cherry MX Red Special Edition Wireless  Corsair Ironclaw RGB Wireless
Archive Server  R3 2200G  Asus B450-I ROG STRIX Wi-Fi ITX  Corsair Vengeance RGB Pro 2x8GB 3200MHz CL16 White  Vega Integrated Graphics  EVGA P2 750W  Prism Wraith Cooler  ITX Open Bench  2x HP SAS Expander  LSI-SAS9211  220TB of HDD Storage
SFF ITX Home PC  i5-7500  MSI B250I Gaming Pro Wi-Fi AC ITX  G.Skill Ripjaws V 2x8GB 2800MHz  Intel Integrated Graphics  Seasonic SSP Flex ATX 300W PSU  Cryorig C7  Velka 3 rev 1.2 SFF ITX Case (Grey)
Laptop  Dell XPS13 2-in-1 7390 (2020)  i7-1065G7  32GB 3733MHz LPDDR4x  Intel Integrated Graphics  1TB NVME M.2  UHD+ (3840 x 2400) InfinityEdge Touch Display
Keyboard Collection  GMMK Full Size  TOFU96 90%  ‖ KBD8x MKII TKL ‖ Drop CTRL High Profile TKL ‖ KBD Bella 75% ‖ GMMK Pro 75% ‖ XD84 Pro 75%  KBD67 V2 MKII 65%  KBD67Lite 65%  TOFU65 65%  KBD Blade 60%  Drop Carina 60%  Southpaw75 60% w/ Left Numpad  OLKB Preonic V3 Ortholinear ‖ CosPad XD24  ‖ KBDPad MKII
Key Cap Collection  GMK Boba Fett  GMK Red Samurai  GMK Laser CyberDeck +Novalties  GMK Arch  MaxKey B&W  Drop MT3 Camillo ‖ Matt3o MT3 /dev/tty  KBDfans Biip Torii Ext-2048  ePBT Less But Better +Novalties  EnjoyPBT Dolch  WinMix Mustard  Drop Skylight Horizon & Slate ‖ Glorious Black Aura
Mechanical Key Switch Collection  Zealios V2 65g  Zealios V2 78g ‖ Zilents V2 67g  Tealios V2 67g  C³ Kiwi ‖ C³ Tangerine  Invyr Holy Panda  Durock T1 67g  Kailh Box Thick Jades ‖ Kailh Box Royal ‖ Kailh Box Heavy Dark Yellow ‖ Kailh Box Heavy Burnt Orange  Kailh Box White  Kailh Box Red  Kailh Pro Purple  Kailh Pro Burgandy  Gateron Ink Black V2  Gateron Black  Gateron Yellow  Gateron Brown  Gateron Green  Gateron Blue ‖ Cherry MX Black ‖ Cherry MX Brown ‖ Cherry MX Red
https://linustechtips.com/topic/1152198-help-with-ram-upgrade/#findComment-13270464
https://ram.userbenchmark.com/     simple as that.  Compare etc. 3200mhz is more than enough when XMP profile is enabled
Also a very good way to increase FPS, get a NVME M.2 card..  Personally, I use 2x Samsung NVME M.2 Evo Plus..  big difference from normal SSD`s... In my opinion.
CPU: I9-9900k OC 5Ghz + Gigabyte AORUS AIO 360 watercooling - GPU: Gigabyte AORUS 2080ti Waterforce Xtreme 11g - RAM: Gigabyte AORUS 32gb(4x8 dual) 3200mhz - MB: Gigabyte AORUS Ultra Z390 - Storage: 2x Samsung 970 EVO Plus 2TB + 1x WD Black 4tb - PSU: Corsair AX760 Platinum Modular - Display: 2x AORUS FI27Q-P
https://linustechtips.com/topic/1152198-help-with-ram-upgrade/#findComment-13270480
Unfortunately just an opinion. The only time you'll get an FPS increase from an NVME upgrade is when the storage transfer speed becomes the bottleneck during gameplay. If a game is coded to drag textures back and forth from storage (most games load what they need into VRAM), then you may see a difference between an SSD to NVME. Otherwise your games might load faster but you will not get an FPS bump. Especially in e-sports titles like Overwatch.
My Builds:
MEGA Desk Build
https://linustechtips.com/topic/1152198-help-with-ram-upgrade/#findComment-13270503
