You should buy a better GPU before you think of upgrading monitors (if you want to play games).
I suggest a used 1080 for about 300 euros or an rtx 2070 super for about 500 euros.
Also, that monitor should be good enough for most gaming and work needs.
If you want to play high fps, competitive games you might want to consider a 240hz monitor.
If you work on color sensitive projects then you might want to look at the Asus ProArt PA32UCG.
Samung Tab S 8.4
https://linustechtips.com/topic/1151422-need-help/#findComment-13264349
9 hours ago, SwedishViking said:
I was thinking about AMD GPU or is Nvidia still better ?
Depends on which price level you are shopping in.
Gaming With a 4:3 CRT
System specs below
CPU: AMD Ryzen 7 5700X with a Noctua NH-U9S cooler
Motherboard: Gigabyte B450 Aorus M (Because it was cheap)
RAM: 32GB (4 x 8GB) Corsair Vengance LPX 3200Mhz CL16
GPU: EVGA GTX 980 Ti SC Blower Card
HDD: 7200RPM TOSHIBA DT01ACA100 1TB, External HDD: 5400RPM 2TB WD My Passport
SSD: 1tb Samsung 970 evo m.2 nvme
PSU: Corsair CX650M
Displays: ViewSonic VA2012WB LCD 1680x1050p @ 75Hz
Gateway VX920 CRT: 1600x1200@75Hz, 1200x900@100Hz, 960x720@125Hz, 800x600@140Hz
Gateway VX900 CRT: 1600x1200@75Hz, 1200x900@100Hz, 960x720@120Hz (Can be pushed to 175Hz)
Keyboard: Thermaltake eSPORTS MEKA PRO with Cherry MX Red switches
https://linustechtips.com/topic/1151422-need-help/#findComment-13265342
I dont play that much, more like a  " allround " person
New, at about 150 euros a 1650 Super, at 200 euros a 1660. At 280 euros an rtx 2060 (ko).
Used, at 100 euros gtx 1060 / gtx 970, 150 euros gtx 980, 200 euros gtx 1070.
Samung Tab S 8.4
https://linustechtips.com/topic/1151422-need-help/#findComment-13269278
