Help me!! (Motherboard)
Go to solution Solved by JensHella,
@Deddie
I just figured a solution for my problem i buy the mobo with 3 usb 2.0 headers and then if i ever need to use the sd card reader i just plug out another usb headed cause i aint gonna be using the sd reader so much
I cant find a nice looking mobo with 4 usb 2.0 headers internally
I know you guys can find some.
It has to be ATX and be 1150 socket
It has to have a red theme
I have no budget for it
Thanks
My pc is named Smaug
Specs: http://pcpartpicker.com/p/P2GKcf and here is a picture http://imgur.com/hBK0q5N
https://linustechtips.com/topic/115132-help-me-motherboard/
@JensHella
Hey
What budget range do you have in mind? Also, will it be intel or AMD?
Elven
Corsair 400R, i7 3770K @ 4.5GHz 16GB, Corsair Vengeance 1600MHz, Gigabyte Z77X-UD5H Motherboard, 240GB Samsung 840 Evo Sata III SSD, 2 x Asus GTX 780 Direct CU2 SLI, Corsair H100i and Corsair AX860i Platinum Power supply.
https://linustechtips.com/topic/115132-help-me-motherboard/#findComment-1539094
I cant find a nice looking mobo with 4 usb 2.0 headers.
Thanks
i think all motherboards have 4 usb headers
Intel i7-3770k @ 4.5 GHz                               DCUII GTX 680                            16GB Corsair Vengeance RAM
Sabertooth Z77 ATX                                      WD Caviar Blue 500GB+ 1TB      Corsair Obsidian 750D
Corsair TX850M Watt PSU                            Bad Custom Water Cooling          Samsung 840 Pro SSD
https://linustechtips.com/topic/115132-help-me-motherboard/#findComment-1539108
http://ca.msi.com/product/mb/Z87-G45-GAMING.html#specification
this one has 8 ports (2 on that back, up to six for front I/O) is that what you mean ?
https://linustechtips.com/topic/115132-help-me-motherboard/#findComment-1539143
May I ask, why?
I have a phantom 820 and that needs 3 usb 2.0 headers and then i have the h100i which need 1 usb 2.0 header so i need 4 usb 2.0 headers
https://linustechtips.com/topic/115132-help-me-motherboard/#findComment-1539147
im mean like on the motherboard itself not on the i/o
https://linustechtips.com/topic/115132-help-me-motherboard/#findComment-1539157
No, it has 2 USB 2.0 headers and one USB 3.0
It says "2 x USB 3.0 + 4 x USB 2.0"
CPU: i7-4770k CPU Cooler: NH-D14 RAM: Crucial Ballistix Sport 8gb GPU: EVGA Superclocked 780 ti MOBO: ASUS Maximus VI Gene PSU: Corsair RM 850 Case: Bitfenix Prodigy M
https://linustechtips.com/topic/115132-help-me-motherboard/#findComment-1539180
Is your Phantom 820 an older model, as it says on the NZXT website that it has 2 USB 2.0 headers and one USB 3.0 header.
https://linustechtips.com/topic/115132-help-me-motherboard/#findComment-1539206
