NEED ADVICE SELECTING A MONITORS
Go to solution Solved by IrishJ,
I'd go with the Asus XG32VQ, given the GPU that you're using, but consider if you're doing serious work, then I'd go with the LG.
Asus when you concentrate more on gaming, LG when you consider on getting work done.
Hello people,
I just want to say thank you in advance to anyone who could provide me with a solid opinion that helps me to make a final desition.
Basicaly, i want to buy a 32" monitor for gaming, designing and movies with the best image quality and Fps as posible with a budged under the 600$.
For production I do 3D renders, digital art, CAD design... blender, autocad, lumion, photoshop, sketchup etc.
For gaming i play FPS, RTS, MMORPG, MOBA, any game tho... from minecraft to star citizen, aion to black desert, apex to escape from tarvok and age of empires to total war, etc.
I have a PC with:
-RTX 2060
-i5 7500
-16gb ram
I have choosen these 2 monitors from my local store:
-Asus Rog strix XG32VQ https://www.asus.com/Monitors/ROG-Strix-XG32VQ/
-LG 32UK550-B https://www.lg.com/co/monitores/lg-32UK550-B
where the LG have the best image quality while the ASUS offers the better FPS... but im not an "expert" so maybe the ASUS provides a better quality over the LG, i just dont know >_< and i dont have any way to test it in real.
Also, both are VA, my local stores do not sell any 4k IPS, and the only 2k IPS dont have free-sync... and about free-sync, there is no G-sync at my local stores.
now my question is... which one is the most efficient in your opinion? and could there be a better option and which one?
EDIT:
i just found this too but havent had the chance to check it and compare it with the others
Samsung LU32R590CWLXZP https://www.samsung.com/latin/monitors/ur59c/
Edited by kyrios01
found more info
https://linustechtips.com/topic/1150779-need-advice-selecting-a-monitors/
then i guess im going for the LG 32UK550-B cuz im going to be doing production stuff plus i dont think i could use those 144fps in games that are worth using it, i think the free-sync might help smothing things more.
thank you, your reply really help me to make a desicion
