Sorry if this is in the wrong forum but I recently upgraded motherboard to ga-ax370 k7 and CPU to 3600 but I knew I'd have to do I bios update so I was planning on using my old 2400g to update bios. However it won't post just stuck on dram led even though the ram was working previously
https://linustechtips.com/topic/1150303-help-needed/
15 minutes ago, Charlie Roberts said:
Wait so you also need a bios update for 2000 series?
Yes un les you update your motherboard in the last wile or it sat "ready for 2000 Ryzen" you will need to use a 1st gen ryzen to update the motherboard.
If you dont have a cpu you can use you can get a lone sampel form AMD:
https://www.amd.com/en/support/kb/faq/pa-100
"i reject your reality and substitute my own"
          --- Workstion --- GamePc ---
"College great Dropout Engineering"
https://linustechtips.com/topic/1150303-help-needed/#findComment-13255738
