I just bought the Stageek cable management raceway kit. It has 9 slim raceway channels 15.6” long. For the past year I’ve had velcro on the back of my 55” Ikea Malm desk with all cables secured off the floor with that. So I’m going to use these raceways now instead on the back. I made a graphic mockup below. Do you recommend a top row for just signal cables and a bottom row (and the built-in cable shelf) for power cables? At various points signal and power cables will have to cross at right angles to each other. By the way the Stageek kit is nice except the 6 straight connectors are useless as they aren’t wide enough to snap on the raceways, but the corner pieces fit fine although not sure if I’ll use those.
https://linustechtips.com/topic/1150192-desk-cable-raceways/
This is going to be my cable management raceway layout on the back of the desk. I'll use 8 of the 9 raceways from the kit The top row is for signal/data cables. The bottom row is for the power cables. I'll be pulling the desk out and installing these Saturday.
https://linustechtips.com/topic/1150192-desk-cable-raceways/#findComment-13261790
