PC won't power on.
Solved by Husky,
8 hours ago, Shael said:No. I've taken apart and reassembled once now. Checking everything I can.
I'm a bit suspicious about the motherboard. Could a dead board possibly be the result?
I am almost certain that the BIOS is out of date and that is why it is not POSTing. Older boards require a BIOS update to support newer Ryzen 2nd and 3rd gen CPUs. Get a hold of an older CPU or go to a shop that can do the update for you.
