Hi guys and gals.  The problem I'm having is trying to switch back and forth from my headphones to my speakers.  It seems to never just work and go smoothly. I always have to go into setting and switch things around or set things back to default.  I stream with my girlfriend and we sit right next to each other and the headphones are really a necessity for streaming, but when we're not streaming my computer is out main way of ingesting media content so the speakers are a must have.  I'm hoping there is a simple fix in windows 10 for switching between two audio sources, but baring that hopefully there is a cheap or free program that can accomplish what I'm looking to do.  Currently I have an S.M.S.l amp going to a few Klipsch speakers. the amp is connected through USB.  I have Corsair Virtuoso RGB wireless headphones. I currently use them wireless through the USB.  They seem to give me even more problems when I don't use the head phones wireless.  Any help would be greatly appreciated. I need this fixed so bad, I'm not even going to plug our twitch stream, and I plug it ever chance I get. I'm a bit like Linus when it come to that.
https://linustechtips.com/topic/1149256-device-switching-problems/
There is a program for Windows called NirCmd which I use to switch between my speakers and DAC for headphones and it seems to work pretty well. You can create a folder with shortcuts and create a Quick Link thingy on your task bar for it.
PC:
AMD Ryzen 9 5900X | AMD Radeon RX 7900 GRE | 32 GB RAM | Arch Linux
Laptop:
MacBook Pro 13" (2019) | Intel Core i5 8279U | 8 GB RAM | macOS
Server:
Intel Core i7 6700K | 16 GB RAM | 2 TB HDD | Debian Linux
