I recently moved my TV and the built-in speakers are effectively useless in the new location.
In canada looking at Best Buy and London Drugs I see a few around $100 but i have no idea about sound.
https://www.londondrugs.com/vizio-36-in-2.1-ch-soundbar---factory-reconditioned---sb362an-f6c-rb/L0713104.html
https://www.bestbuy.ca/en-ca/product/polk-audio-signa-solo-sound-bar-open-box/12371931
https://www.bestbuy.ca/en-ca/product/toshiba-ty-sbx130-16-watt-2-0-channel-sound-bar-only-at-best-buy/11642383
https://www.bestbuy.ca/en-ca/product/thonet-vander-250-watt-sound-bar-with-wireless-subwoofer/13967015
Any advice on a particular soundbar to get passable sound quality at a low cost and is it worth spending the money for a setup with a subwoofer?
I am generally content with my built-in speakers so I don't need anything fancy and while I don't have a budget I want to minimize cost.
A soundbar would fit better in my living room than speakers.
https://linustechtips.com/topic/1149073-basic-audio-set-up/
No soundbars! Crappy small speakers unless you spend big bucks. If you're not completely strapped for space, I would always recommend high quality bookshelf speakers
Nothing beats a quality 2.0 or 2.1 setup IMO.
For less than $100, I'd recommend this. They're the tried and tested Dayton B452s, but with an integrated amp and bluetooth connectivity.
https://www.parts-express.com/dayton-audio-mk402btx-powered-bluetooth-4-2-way-bookshelf-speaker-pair-with-35mm-aux-in--300-467
If you don't mind doing a little setup, I'd recommend getting the Dayton B652s for $45
https://www.parts-express.com/dayton-audio-b652-air-6-1-2-2-way-bookshelf-speaker-with-amt-tweeter-pair--300-651
And this amp - it won't get them absurdly loud, but it'll be enough and it sounds good. $30
https://www.parts-express.com/dayton-audio-dta-1-class-d-ac-dc-battery-powered-mini-amplifier-15-wpc--300-380
i5 12600KF | Zotac RTX 4080 Gaming trinity | Team Vulcan 2x16GB DDR4 3600 | ASRock Z690M-ITX/ac | WD Black SN850x 2TB
Cooler Master NR200P v2 | ID Cooling Zoomflow 280 XT | SeaSonic Focus SGX-750 | Thermalright 2x140mm + 2x120mm aRGB
LG C2 OLED 48" 120hz | Epomaker TH80 (Gateron Yellow) | Logitech MX Master 3 | Koss Porta Pro Comm
https://linustechtips.com/topic/1149073-basic-audio-set-up/#findComment-13245855
I could fit speakers, but my TV stand has an area for DVD players etc that would fit a soundbar well. And I don't need particularly good quality of sound, so long as they work and hold up.
Also, note that I am in Canada, the suggested items are twice the price here (or shipping from your link is almost as much as the items).
https://linustechtips.com/topic/1149073-basic-audio-set-up/#findComment-13246299
