I decided to build pc, parts I have chosen are: ryzen 5 1600 af model, mb asrock b450m-hdv r4.0(I can go 320 mb CUZ I don't overclock, just for out of the box use light gaming/browsing web) , ram value g.skill 16 gb 2666mhz CL 19, f4-2666c19d-16gnt kit of 2. And I have allready gpu, psu, case.
The problem is will everything will work together good like mb whit cpu(whitout bios update) and ram on mb, looked mb cpu and ram support and it doesn't show that it supports that cpu model(the new af) and no support for that ram, any ram whit 2666mhz from g.skill
Tnx for help :)
  • CPU
    Ryzen 5 1600 af 3.2 ghz
    Cooler AMD Wraith Prism rgb
  • Motherboard
    Asrock b450m-hdv r4.0
  • RAM
    16gb g.Skill 2666MHz
  • GPU
    Inoo3d 1650 super twin x2 oc
  • Case
    Genesis titan 750
  • Storage
    Kingston a400 240gb(system)
    Seagate barracuda 2tb 7200rpm(storage)
    Samsung 1tb 7200rpm(backup)
  • PSU
    Fsp si series 700w 50arn 88% efficiency
  • Display(s)
    Dell ultra sharp 24" 1080p
  • Cooling
    X4 Led case fans
  • Keyboard
    Redragon k552-rgb
  • Mouse
    Trust rgb gaming mouse
  • Sound
    Steelseries artic 1
  • Operating System
    Windows 10 home
https://linustechtips.com/topic/1149051-new-pc-build-need-help/
If it's for light use I dont see why you cant get by with a Ryzen 3. Not like that board will appreciate a 6 core either
AF could require BIOS update, seeing how old versions of Ryzen Master cant pick it up,
Desktop benching:
https://linustechtips.com/topic/1149051-new-pc-build-need-help/#findComment-13245746
OH boy ?
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
    Genesis titan 750
  • Storage
  • PSU
  • Display(s)
  • Cooling
    X4 Led case fans
  • Keyboard
    Redragon k552-rgb
  • Mouse
  • Sound
    Steelseries artic 1
  • Operating System
    Windows 10 home
https://linustechtips.com/topic/1149051-new-pc-build-need-help/#findComment-13245789
10 hours ago, web0623 said:
I agree with Jurrunio.  You might need a bios update, the AF chip is a 12nm process and closer to a 2600 than a 1600 14 nm.
But if it's board supports r5 2600 then it should support this af chip, or no?
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
    Genesis titan 750
  • Storage
  • PSU
  • Display(s)
  • Cooling
    X4 Led case fans
  • Keyboard
    Redragon k552-rgb
  • Mouse
  • Sound
    Steelseries artic 1
  • Operating System
    Windows 10 home
https://linustechtips.com/topic/1149051-new-pc-build-need-help/#findComment-13246702
