Hello everyone I just recently built a new gaming PC and I cannot get a post. The fans are spinning and the RGB on the devices are lit. I was wondering if maybe if my motherboard needed a BIOS update? I was wondering if anyone has some advice. Specs listed below.
Specs:
i9 9900k
Cooler: Cooler Master MasterLiquid ML240L RGB
Mobo: ROG STRIX Z370-E GAMING
Ram: G.Skill Trident Z RGB 32 GB (2 x 16 GB) DDR4-3200 Memory
GPU: Geforce RTX 2080ti
Storage: 500gb Samsung 970 evo NVMe M.2
PSU: Corsair RM750
The case is a Lian Li PC-O11 Dynamic ATX Full Tower Case
https://linustechtips.com/topic/1149036-need-help-with-new-build/
2 hours ago, web0623 said:
First thing I would do is reseat all the cards, maybe try RAM sticks individually in case one is bad.  Perhaps try the integrated graphics alone to see if that boots.
I put the ram in my old rig and it works as normal, the gpu works as well. When trying on board to post still no output.
