Audio in my headphones stopped working all of a sudden. I tried reinstalling all of the drivers, but nothing works. Restarted the system, Nothing. Checked audio connection in the system, nothing wrong with it.
I think the front panel audio jack is not working. is there a way to fix it?
UPDATE!!! ISSUE IS NOW RESOLVED! THANKS TO EVERYONE WHO HELPED!!
https://linustechtips.com/topic/1148739-audio-not-working/
Possible that you audio setting were change ( windows bugs )
Go
setting
system
sound
Try different setting -- Also in top right in same location , you have --> sound control panel .  You have more details there.
You can play music, and see if you get sound by changing things.
https://linustechtips.com/topic/1148739-audio-not-working/#findComment-13243720
Go
setting
system
sound
still doesnt work
https://linustechtips.com/topic/1148739-audio-not-working/#findComment-13243731
Just now, Patrick H said:
I have MPOW H7 headphones. They're plugged into the front panel audio headphone jack.
Do you have anything else to test the port with? Some cheap earbuds... ?
https://linustechtips.com/topic/1148739-audio-not-working/#findComment-13243735
yes. just tested with some earbuds. Still nothing
Can you test the rear ports? Will probably have to switch the windows device
https://linustechtips.com/topic/1148739-audio-not-working/#findComment-13243745
3 minutes ago, Patrick H said:
nope. still nothing
Take a screen shot of your sound control panel. open up a command prompt, type in "control mmsys.cpl" and make sure you are on the "playback" tab
https://linustechtips.com/topic/1148739-audio-not-working/#findComment-13243760
1 minute ago, Patrick H said:
Are your headphones plugged in, in this picture? Currently your VG240Y display is getting audio signals, and your digital output (toslink maybe) is set as a headset for call applications like discord.
https://linustechtips.com/topic/1148739-audio-not-working/#findComment-13243783
soundpanel.PNG.630545ac18f0b1d713964045718d3d29.PNG woops. plugged them in, and set them as default audio device. still nothing working
https://linustechtips.com/topic/1148739-audio-not-working/#findComment-13243787
Can you set them to just default everything to be sure nothing wonky is happening with the communications settings?
https://linustechtips.com/topic/1148739-audio-not-working/#findComment-13243791
