Graphics card issue
Solved by WhiteAirLock,
17 hours ago, Worstcaster said:Sorry, I've never actually done it before. I was just tossing it out as a possible solution. A youtube search might have a good tutorial.
Alright, that's not a problem but thank you anyway for the helpful hint.
If someone of you guy's, has similar problem like I do, then here is possible repair solution...
Some guy from this forum send me a URL via Twitter https://www.techpowerup.com/vgabios/
It helped me to flash the latest vBIOS and now the GPU works on my PC and the eGPU docking station on my ThinkPad.
You can read the current bios via GPU-Z tool and flash it via ATIFlash (AMD GPU's) or NVFlash (Nvidia GPU's)
These tools are FREE!
If you see a site, which are selling those, then it's a scam
