I play GTA V and noticed I was only getting ~35fps on direct X11 ultra settings. I have tried all sorts to increase my FPS but can’t. Currently use Direct X10 and get between 80-110fps but feel my computer should be able to handle Direct X11 (as I want the extra detail Direct X11 provides).
My pc:
Intel-Core i9-9900KF,
RTX 2080Ti 11GB,
32GB RAM,
1TB SSD
P.s I have checked my drivers and installed the latest updates for drivers and GPU.
Does anyone know how I could increase my FPS to allow me to use Direct X11?
https://linustechtips.com/topic/1148184-low-fps/
My pc:
RTX 2080Ti 11GB,
32GB RAM,
1TB SSD
2080ti and 35fps ... that’s really low. What resolution you playing at?
   @Whiro tag or quote will do the trick
Steam Deck OLED 512gb , all other pc’s are gone
                                          WHIRO
         THE FIRST OF DEATH AND DARKNESS
        He feast on the dead to inherit their power
https://linustechtips.com/topic/1148184-low-fps/#findComment-13238917
