What to choose (Sound Card)
Solved by ToxicFire,
unless there is something audibly wrong with your onboard when using headphones, don't get a soundcard. the soundcard will also probably have NO effect on the speakers.
... That's not how this works.
I'll be honest with you, you probably don't need a sound card. You need an Amp. A sound card has a built-in amp, but they aren't great.
What motherboard do you have? Maybe the onboard sound is just really weak.
You don't need a $100-$200 sound card. At that price range, get a DAC/Amp. Others can help you with that.
If you still want a sound card, shameless plug.
Theres a good video that talks about this from tek syndicate
