2011 Macbook Pro screen issues
Solved by TubsAlwaysWins,
10 hours ago, Bombastinator said:Argh. Software or hardware still then. Could be hardware. The thing is old. Less likely but possible. I don’t know enough about OSX to be able to help with software. A thought: does it have an external monitor port and can you get video out of it?
Looks like software? The led stays on with no display until the screen times out. When you wake it back up it comes up fine
Edit : NVRAM reset fixes it
