Just now, jjbeebe said:
Microsoft 3600
Yeah I saw your screenshot after my post. Try to install the software here: https://www.microsoft.com/accessories/en-ca/products/mice/bluetooth-mobile-mouse-3600/pn7-00002#techspecs-connect
Often the driver is included with the software.
With Bluetooth there is  “discovery”, “pairing” and driver.  One device has to search out and “discover” the other, then they need to “pair”. During this the driver has to work.  Lack of either could read as a driver error, or there might be an actual driver error.  If both are “discoverable” but neither is doing any discovering nothing is going to happen.
1 minute ago, jjbeebe said:
I have installed the driver from the support page
I would try to uninstall the mouse software and then right click on the device in Device Manager select uninstall and check "Delete the driver software for this device". Then reboot your PC and install the software again.
all my drivers are updated (manually installed) to try and fix the issue and windows is fully updated
Even if your drivers are updated you have a driver issue right now, so your mouse driver might be corrupted. So try to uninstall the device (follow the steps in my previous post) and then install it again.
5 minutes ago, jjbeebe said:
Not sure how to fix the driver error, I have installed the driver from the support page etc.. and no go. they both can see one another.
It might (or might not be) be useful to point out that Bluetooth pairing is relatively complex and messy.
It’s a complicated exchange with several steps.
It’s possible something got missed or messed up in the process even if the driver issue is fixed.  Turning everything off and on and restarting the whole process would be needed at each point to check function.
gave this a shot also
