So i've just finished building my first rig (nothing fancy but works like a charm). I got a very good deal on 2 x rgb ram stick (2x8gb) and i also ordered some led strips (Deepcool RGB200PRO Addressable RGB LED lighting kit). Problem is that these use add_header (+5v w/ 3 pins) and i only have a 12v grb header on my motherboard. Will it work? the reason i chose this kit is because i want to sync my ram with the strips.
https://linustechtips.com/topic/1145887-rgb-strips-headers/
Since those 12v rgb don't have such pin, no, it won't work out of the box. Additional adapter is required.
Purify your Windows 10/11, don't give Microsoft anything that you don't want to share.
https://drive.google.com/open?id=1ZwVs9zrM493rjD42E2Pf0YcOkaW92ZUo
Tips for folding on laptop:
Lazy man wants upgrades from the sky.
https://stats.foldingathome.org/donor/Spakes
https://linustechtips.com/topic/1145887-rgb-strips-headers/#findComment-13220154
