I am playing games that are not to intense for my computer, like Rocket League and I will get random screen freezes for like 1/2 of a second. How do I fix this?
I have a GPU temp monitor installed an it seems to drop every time I get a freeze. I don't think it is thermal throttling because it drops at different temps for different games.
Any help is appreciated. Also, I just installed 2 new Corsair 140 fans to the front of my case, to make a total of 3 case fans and it is still freezing.
My PC:
EVGA GeForce GTX 1070
Asus Z170 PRO GAMING
Intel i7-7700k @ 4.2GHz
16GB of ram
256GB ssd, 1 TB HDD
Windows 10 64 bit
https://linustechtips.com/topic/1145801-screen-freezes-help/
My PC:
16GB of ram
256GB ssd, 1 TB HDD
Windows 10 64 bit
Try ddu all drivers in safe mode and reinstalling them again.
Also what brand and model of psu you have?
   @Whiro tag or quote will do the trick
Steam Deck OLED 512gb , all other pc’s are gone
                                          WHIRO
         THE FIRST OF DEATH AND DARKNESS
        He feast on the dead to inherit their power
https://linustechtips.com/topic/1145801-screen-freezes-help/#findComment-13219664
1 minute ago, CAB1526 said:
What do you mean by ddu?
I have a Corsair HX750 platinum rated psu
This psu is really decent unit.
DDU (Display Driver Uninstaller) it removes all drivers from your pc.
                                          WHIRO
https://linustechtips.com/topic/1145801-screen-freezes-help/#findComment-13219672
8 minutes ago, CAB1526 said:
where do i find that? GeForce experience?
https://www.guru3d.com/files-details/display-driver-uninstaller-download.html
                                          WHIRO
https://linustechtips.com/topic/1145801-screen-freezes-help/#findComment-13219685
14 minutes ago, CAB1526 said:
it told me to go into safe mode but i could not use the program from there. Also, I just downloaded new drivers so it should be fine.
Do u have any other suggestions to help me?
Recommended usage
  • You MUST disconnect your internet or completely block Windows Update when running DDU until you have re-installed your new drivers.
  • DDU should be used when having a problem uninstalling/installing a driver or when switching GPU brand.
  • DDU should not be used every time you install a new driver unless you know what you are doing.
  • DDU will not work on network drive. Please install in a local drive (C:, ? or else).
  • The tool can be used in Normal mode but for absolute stability when using DDU, Safemode is always the best.
  • If you are using DDU in normal mode, Clean, reboot, clean again, reboot.
  • Make a backup or a system restore (but it should normally be pretty safe).
  • It is best to exclude the DDU folder completely from any security software to avoid issues.
                                          WHIRO
https://linustechtips.com/topic/1145801-screen-freezes-help/#findComment-13219741
