3 minutes ago, Yiannis15 said:
Hello today I removed my ram from my PC and the motherboard has 2 ram levers you have to open to be able to remove the ram. But I forgot about it and only opened one lever. But the ram was easily removed. Is there a way it could be damaged?
Nope. Those levers just stop the ram moving. Even if you snapped them off the ram would still seat and work. Most modern motherboards only have 1 lever per slot anyways. All you'll have done in moved the lever out the way when pulling up. No harm done.
Gaming PC: • AMD Ryzen 7 3900x • 16gb Corsair Vengeance RGB Pro 3200mhz • Founders Edition 2080ti • 2x Crucial 1tb nvme ssd • NZXT H1• Logitech G915TKL • Logitech G Pro • Asus ROG XG32VQ • SteelSeries Arctis Pro Wireless
Laptop: MacBook Pro M1 512gb
https://linustechtips.com/topic/1145550-removing-ram-problem/#findComment-13217340
