Just now, Harry777 said:
Is hardline tubing hard on a 2080ti with a 9900k.
Im gonna overclock it extreme btw
Its just as hard as doing it on other systems, if you have an understanding of custom water loops (and have built one before) then go for it but if you haven't done one before or don't know much about custom water loops then read up on it and start with a soft tubing one
PC: Ryzen 9 5900x | RTX 3080Ti | Asus Prime B450-PLUS | ASUS ROG Strix 1000W Gold | 32GB Corsair Vengeance 3200MHz RAM | 512GB NVME SSD + 2TB NVME + 6TB WD BLACK | Windows 10 Pro + Windows 7 Ultimate
Laptop: MacBook Pro 15" 2018 | i9-8950HK | Radeon Pro 560X | 32gb RAM | 1tb SSD
iPhone 13 Pro Max | 256GB | iOS 16.5 with Dopamine 2 + Trollstore 2
https://linustechtips.com/topic/1145363-help/#findComment-13215781
hardline tubing doesn't increase in difficulty as the components get more expensive, a 2080 ti and i9 are roughly the same shape as any cheaper compatible parts so it's all the same
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1145363-help/#findComment-13215827
i only done a soft tube loop before is it a lot harder then soft tube?
https://linustechtips.com/topic/1145363-help/#findComment-13221247
I don't know, I would recommend watching some YouTube videos on it (Hardline Water Cooled PC Build Log - Yes, you can play Battlefield on it)
https://linustechtips.com/topic/1145363-help/#findComment-13221271
