You want it like this:
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
https://linustechtips.com/topic/1145243-front-mounted-radiator/#findComment-13214634
2 minutes ago, Spaceman_Wil said:
So having had the same question and doing tons of research on it previously, what I learned was best practice is case | radiator | fans but in the end you'll only see a couple degrees of a difference if any.
Awesome, thank you!
https://linustechtips.com/topic/1145243-front-mounted-radiator/#findComment-13214636
Case, radiator, fans.  For 1 simple reason.  The fans intake from the front, so any dust gets stuck on the other side of the radiator so all you have to do to clean it is take off the front panel and dust it.  If it's Case, Fans, Rad, you'll have to remove the fans to get to the dust trapped between the fan and rad.
QUOTE ME IN A REPLY SO I CAN SEE THE NOTIFICATION!
When there is no danger of failure there is no pleasure in success.
https://linustechtips.com/topic/1145243-front-mounted-radiator/#findComment-13214668
Also. When using setup 1. The radiator is acting as a shroud, allowing the fans to get more air for intake. Overall improving airflow to the case.
Gaming PC:
Linux PC:
https://linustechtips.com/topic/1145243-front-mounted-radiator/#findComment-13216794
