So i picked up a new case for my pc with the hopes of moving everything into a nice new nzxt case. I also grabbed a new psu from corsair. 550w gold fully modular  ....to replace my old 500w white. I got everything moved over...fired it up and the cpu fan did a quarter turn and nothing. I started to systematically eliminate possibilities.  I removed all the ram and put in a stick i know was working,, made sure all my connections were tight....disconnected all the front panel connectors ...removed gpu....It wasn't till i removed the power to the ssd it booted up....So i though...ok....i grabbed a new ssd and tried it...nothing...no power....so now i concluded that it was not the ssd....i tried a new ssd power connector...nothing...i tried s dif ssd cable to the mobo...nothing....what are your thoughts....could it that the new power supply has issues?
https://linustechtips.com/topic/1144969-help-psu-issues/
I think it is the new power supply. The way to verify is to hook back in your old PSU and if it works fine, then we know for sure. I would imagine you would've caught it by now if it was the issue, but you may double check your connections going into the modular PSU. Maybe one is loose or plugged in funky?
https://linustechtips.com/topic/1144969-help-psu-issues/#findComment-13212454
Did you keep the old power cables or swapped them?
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
https://linustechtips.com/topic/1144969-help-psu-issues/#findComment-13212462
It helps a lot to add a spec list just in case
My first thought is something not being plugged in all the way, might want to double check if you haven't
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1144969-help-psu-issues/#findComment-13212487
