V Lang - http module not found??
Solved by Shubhendra,
instead of using "import http" use "import net.http"
module main
import time
import net.http
fn main() {
resp := http.get('https://vlang.io/utc_now') or {
println('failed to fetch data from the server')
return
t := time.unix(resp.text.int())
println(t.format()) // yyyy-mm-dd hh:mm
