Hello,
I built a gaming pc last week, and everything is working, all the drivers are installed and the BIOs is updated. I do not have a wifi card so I have been using ethernet this whole time. It has been working until today. I plug in a lan cable and it says nothing is connected, but the internet will pop up. Here’s the weird part though. I have a router that is mounted on the wall, and it’s weird because i can’t take it off, it’s wifi that is provided by my apartment complex that I switched to yesterday. The wifi worked all yesterday, but stopped today. Now, when i connect a lan cable to the router and then plug it into my PC it turns the router off. Not sure what is going on and I have tried everything. Can anyone help?
PC specs
I7-9700K
MSI MPG Z390 Gaming Plus Motherboard
RTX 2060 Super 8GB Founders Edition
16 GB Corsair Vengeance RGB
Corsair H100i AIO
2 TB Seagate Barracuda
500 GB Samsung 860 EVO
https://linustechtips.com/topic/1143772-lan-port-not-working/
Easy things first - try another cable. If that fails, try same port, same cable with another device, if that is an option.
HAL9000: AMD Ryzen 9 3900x | Noctua NH-D15 chromax.black | 32 GB Corsair Vengeance LPX DDR4 3200 MHz | Asus X570 Prime Pro | ASUS TUF 3080 Ti | 1 TB Samsung 970 Evo Plus + 1 TB Crucial MX500 + 6 TB WD RED | Corsair HX1000 | be quiet Pure Base 500DX | LG 34UM95 34" 3440x1440
Hydrogen server: Intel i3-10100 | Cryorig M9i | 64 GB Crucial Ballistix 3200MHz DDR4 | Gigabyte B560M-DS3H | 33 TB of storage | Fractal Design Define R5 | unRAID 6.9.2
Carbon server: Fujitsu PRIMERGY RX100 S7p | Xeon E3-1230 v2 | 16 GB DDR3 ECC | 60 GB Corsair SSD & 250 GB Samsung 850 Pro | Intel i340-T4 | ESXi 6.5.1
Big Mac cluster: 2x Raspberry Pi 2 Model B | 1x Raspberry Pi 3 Model B | 2x Raspberry Pi 3 Model B+
https://linustechtips.com/topic/1143772-lan-port-not-working/#findComment-13205389
