Hey all,
I got a MSI Tomahawk B450 MAX and a Ryzen 5 3600 and looking for some new Ram now. Found a G Skill Trident Z 16GB Kit (3600MHz and CL 18) for around 100€ in Germany.
Should i take it and what would you take?
Thanks for your opinion
CPU: R5 3600
Motherboard: MSI B450 Tomahawk MAX
RAM: 2x8Gb Trident Z Neo 3600MHz CL16
GPU: EVGA GTX 1060
Case: Cooler Master NR 600
https://linustechtips.com/topic/1143748-ram-buyers-help/
1 hour ago, theskeleti said:
what should i prioritise? Ram Speed or Cas Latency?
I also found a Kit of a 3000MHz Cl14 Kit for a bit more.
Ryzen likes fast ram. I would recommend 3600Mhz
Gaming Build:
CPU: Ryzen 7 3800x   |  GPU: Asus ROG STRIX 2080 SUPER Advanced (2115Mhz Core | 9251Mhz Memory) |  Motherboard: Asus X570 TUF GAMING-PLUS  |  RAM: G.Skill Ripjaws DDR4 3600MHz 16GB  |  PSU: Corsair RM850x  |  Storage: 1TB ADATA XPG SX8200 Pro, 250GB Samsung 840 Evo, 500GB Samsung 840 Evo  |  Cooler: Corsair H115i Pro XT  |  Case: Lian Li PC-O11
Peripherals:
Monitor: LG 34GK950F  |  Sound: Sennheiser HD 598  |  Mic: Blue Yeti  |  Keyboard: Corsair K95 RGB Platinum  |  Mouse: Logitech G502
Laptop:
Asus ROG Zephryus G15
Ryzen 7 4800HS, GTX1660Ti, 16GB DDR4 3200Mhz, 512GB nVME, 144hz
NAS:
QNAP TS-451
6TB Ironwolf Pro
https://linustechtips.com/topic/1143748-ram-buyers-help/#findComment-13202668
you can calculate here: https://notkyon.moe/ram-latency.htm
But with ryzen this is not the whole story. The infinity fabrics speed (that connects the CPU cores to each other and everything else) is tied to RAM speed. With 3000Mhz Ram you will make it runn slower than it is able to. With 3600Mhz ram you can max it out. Therefore get the 3600 Kit enable XMP (or however AMD calls that) and be golden!
FOLDING MONTH 2021! GOGOGO and save on some heating costs 🙂
https://linustechtips.com/topic/1143748-ram-buyers-help/#findComment-13202669
