Did my GPU just die? Fanless gpu not giving signal to monitor
Solved by CharlesM2020,
Greetings @GoogleAssistantIsAVirus,
I have had experience with HDMI ports in televisions dying, it is a known issue with old TV's. I wonder if changing the adapter to a heavier one put enough stress on the HDMI port for it to fail. Are you able to try using a DVI->VGA adapter instead of a HDMI->VGA adapter to see if you can get signal off the DVI connector?
