I wouldn't say it's slippery but the side grip is just OK due to the design. Hard plastic if you're wondering
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
https://linustechtips.com/topic/1142829-logitech-g304-help/#findComment-13195277
14 hours ago, Mahbub said:
i currently have logitech g603 and it has plastic sides which r slippery.. i recently came acrosss g304.. thinking to buy it.. i wanted to ask does the g304 too have slippery plastic sides or rubber sides?
The G603 has smooth rubberized sides, which can be slippery. The G305, on the other hand, has finely textured plastic on the sides. If you need more grip, Lizard Skins grip tape is great, you can just cut and apply them to the sides.
https://linustechtips.com/topic/1142829-logitech-g304-help/#findComment-13197262
