coil whine
Go to solution Solved by LukeSavenije,
1 minute ago, tom435 said:
so does that mean everything is fine and I dont need to worry about it?
nothing about coil whine is damaging, it's just really annoying
Hi!
I bought a Palit gamerock rtx 2070 super today. But I have a problem whenever I go into Beamng.drive my psu starts to coil whine and its really loud. And also it gets even louder if I turn on reflections also reflections look odd. They are just red or green no other color looks really weird. Also on camera isnt that loud. Can this be a sign that the psu is bad or that I dont have enough watts?
specs:
mobo: asus prime b250m-plus
cpu: i5-6600k
ram: 2x8gb ddr4 3000mhz gskill aegis (running at 2133mhz)
gpu: rtx 2070 super
psu: be quiet pure power 11 600watt
1x toshiba 5.4k 500gb hdd
1x 7200rpm 2tb seagate barracuda
1x m.2 ssd intel 760p 256gb
5x 120mm fans (2xwith blue led)(other 3 fans are connected to rgb hub)
1x rgb strip
1xrgb hub
https://linustechtips.com/topic/1142537-coil-whine/
it's normally a thing mostly on double forwards rather than ACRF, like what your pure power 11 here is, but still more likely than on llc's
coil whining just means you overloaded the transformer, which shouldn't cause damage, let alone these kinds of things
https://linustechtips.com/topic/1142537-coil-whine/#findComment-13192711
https://linustechtips.com/topic/1142537-coil-whine/#findComment-13192963
