Is the display cable plugged in to the back of the motherboard or the graphics card?
What games are you playing, what settings are you using (including display resolution), and what FPS are you getting?
8 minutes ago, Sticky pilot said:
its display port into a 1920 x 1080 165 hurtz monitor on mw i get 165 and itll drop to 50
How’s the temps of that card when you playing?
   @Whiro tag or quote will do the trick
Steam Deck OLED 512gb , all other pc’s are gone
                                          WHIRO
         THE FIRST OF DEATH AND DARKNESS
        He feast on the dead to inherit their power
Just now, Sticky pilot said:
highest of 62 c
So temps are definitely not the issue in here.
Is your drivers up to date?
                                          WHIRO
2 minutes ago, Sticky pilot said:
yeah i update frequently
Ok next questions.
Is it brand new system? Is this drops from the beginning or they started just now?
Also what brand and model is that psu you have? Is the card power cable connected properly? Is it one cable (daisy chained)?
                                          WHIRO
