So a friend of mine bought an EVGA 2060 (I will make an edit to list the exact model when he responds to me). The problem is that when he installed the card and the drivers for the card, he didn't have access to the NVIDIA control panel and he couldn't change the resolution in windows. So he turned to me. I had him do the following:
  1. Run DDU (yes in safe mode.) then install the driver
  2. Perform a clean install
  3. Restart NVIDIA Container Service , then clean installed
  4. After a DDU, install the latest driver straight from the geforce.com/drivers website. (He had installed GeForce Experience from EVGA and installed the driver that way before i helped him.)
  5. installing NVIDIA control panel from the windows store (i didn't even know that was a thing until i was googling the problem)
  6. Resetting windows then installing the driver
My thought is that there is a software issue somewhere, he can load windows using the basic display drivers and the 2060. Taking a look into device manager shows that windows stopped it for some reason (Code 43 if that helps.). I'm not quite sure where the issue is. The only other nuance is that on the box it recommends a 500w psu he happens to have a 450w psu. To my knowledge if it was a power draw issue, windows wouldn't even boot, he wouldn't even be able to POST. I don't think that it would prevent a driver from installing if there was a power issue.
Any thoughts?
https://linustechtips.com/topic/1142339-rtx-2060-driver-issues/
5 minutes ago, mthilton said:
Any thoughts?
Is the windows up to date? I know sometimes this is causing problems
   @Whiro tag or quote will do the trick
Steam Deck OLED 512gb , all other pc’s are gone
                                          WHIRO
         THE FIRST OF DEATH AND DARKNESS
        He feast on the dead to inherit their power
https://linustechtips.com/topic/1142339-rtx-2060-driver-issues/#findComment-13190792
That isn't how it works I think.  Windows would boot and then when GPU is under load that's when you'll run into issues,  performance or otherwise.
I know the PC does a self check when booting but I kinda doubt it puts the GPU under full load during that.
Quote
Why?
-Scott Manley, 2021
https://linustechtips.com/topic/1142339-rtx-2060-driver-issues/#findComment-13190875
See thats what i thought but i figured that id throw it out there to see if i was incorrect in my thought process
57 minutes ago, Mark Kaine said:
Quote
Why?
Idk when i was googling that was one of the things in the top results. Not sure why that would do anything tbh but i was desprate
https://linustechtips.com/topic/1142339-rtx-2060-driver-issues/#findComment-13190973
I see,  well restarting this process isn't recommend - it's kind of like the opposite what you're trying when using DDU - having a clean state.
I've never seen this recommended either,  I don't doubt you, just saying it's perhaps counter productive.
I mean,  it could be a driver issue for sure I'd try DDU again, then install the driver from NV site normally without messing with anything.
BTW I think I had this too (no control panel),  once, it's usually a Windows issue iirc and a PC restart fixed it.
It's kinda similar to how GFE sometimes just stops working for no reason,  restart PC and most of the time that fixes it.
-Scott Manley, 2021
https://linustechtips.com/topic/1142339-rtx-2060-driver-issues/#findComment-13190986
Well now i know, thanks!
We did this too, to no avail. This was actually the first thing that we did.
We also tried just a good ole restart after we DDU, then installed the driver and that didnt work either
https://linustechtips.com/topic/1142339-rtx-2060-driver-issues/#findComment-13191007
