Need help updating bios
Go to solution Solved by redteam4ever,
For starters, you didn't specify your motherboard model, which is the most important specification. Luckily, in your earlier post, you indicated that you have a MSI B450 Tomahawk motherboard. While some people might be able to help you straight away, either because they build PCs for living or have a similar motherboard to yours, I cannot imagine that most of the good people here are in that situation, so they look for the manual. I did that and here is a solution for you:
Updating BIOS with Flash BIOS Button
Before updating: Please download the latest BIOS file that matches your motherboard model from MSI® website and rename the BIOS file to MSI.ROM. And then, save the MSI.ROM file to the root of USB flash drive.
Important
Only the FAT32 format USB flash drive supports updating BIOS by Flash BIOS Button.
  1. Connect power supply to CPU_PWR1 and ATX_PWR1. (No other components are necessary but power supply.)
  2. Plug the USB flash drive that contains the MSI.ROM file into the Flash BIOS Port on rear I/O panel.
  3. Press the Flash BIOS Button to flash BIOS, and the LED next to the button starts flashing.
  4. After the flashing BIOS process is 100% completed, the LED would be off simultaneously.
For more information on where to find the button and the LED, refer to the manual. If you don't understand the instructions, tag me and specify which part yo need to clarify. Good luck :)
I have a build with a Ryzen 5 2600 CPU with a XFX Radeon Rx 5700 8GB GPU. The computer was working fine but it just decided not to turn on. On the motherboard it shows an EZ Debug light for the CPU. I read that updating the bios will help. How do I update to bios with only a usb stick. Any help would be great.
https://linustechtips.com/topic/1142308-need-help-updating-bios/
What brand and model of mobo you have?
   @Whiro tag or quote will do the trick
Steam Deck OLED 512gb , all other pc’s are gone
                                          WHIRO
         THE FIRST OF DEATH AND DARKNESS
        He feast on the dead to inherit their power
Important
My heart belongs to AMD but that doesn't mean I furiously hate Intel or NVIDIA :)
MAIN RIG AMD Ryzen 7 1700 | ASRock Fatal1ty X370 Gaming-ITX/ac | MSI HD7950 OC 3GB | G.Skill Ripjaws V 2x8GB @ 2666MHz (Samsung D-Die) | ADATA SX8200 480GB NVMe SSD & Seagate Barracuda 120 1TB SSD & WD Black 500GB | Sharkoon QB One
LAPTOP Lenovo Yoga Slim 7 (14ARE05) - AMD Ryzen 5 4500U | AMD Vega 8 (Renoir) | 16GB RAM | SKHynix PC601 512GB (OEM) | 1080p 300nit non-touch display
Important
Do I have to disconnect the other power sources that are already plugged into my mother board?
No, you can leave everything connected.
Strictly speaking, CPU power and ATX power are the only power input connectors on a motherboard, but I think you meant to say if you can leave other components connected to the motherboard, so this is an answer to that.
Okay. Will try that now. I downloaded the latest update to the usb and will look for the flash bios light.
Important
This worked thank you for helping!
I'm surprised that a BIOS update helped with a non-booting system (that worked before) but at the same time glad that I helped you with it :)
