Unless it's a prebuilt system, any board that is compatible with your current CPU GPU and RAM will do
Desktop benching:
it was prebuilt.So I have to get the same exact mobo?why cant it be a different mobo thats compatible with my components if its pre built?
The limiting factor can be that some prevuild using different layout of mobos and your screw holes may be off , plus what psu you got there? Is it one of the weird ones where you have like 18pin instead of 24pin ? In that case you may need to replace psu and case. Rest of components (cpu ram and gpu) should be alright.
   @Whiro tag or quote will do the trick
Steam Deck OLED 512gb , all other pc’s are gone
                                          WHIRO
         THE FIRST OF DEATH AND DARKNESS
        He feast on the dead to inherit their power
I got a 700Watts 24pin so psu is alg
What’s rest of your spec? And also what prebuild is it?
                                          WHIRO
  • 2 weeks later...
