Weird crash and after moment system restarted on 9900K and 2080 Ti.
worry
Monitor:AORUS AD27QD
Cpu: i7-9900K stock 4.7 with Noctua NH-D15
Gpu: Rtx 2080 Ti Aorus Xtreme Waterforce ( stock no oc,temps max 63C on load )
Ram: 32gb 2x16 GB DDR4 GSKILL 3000MHZ XMP
Psu: Seasonic Ultra Prime Titanium 850W
mb: Asus Prime Z390-A
SSD: Crucial 1TB
HDD: WB BLUE 1 TB
Case: Cooler Master Cosmos C700P
Hello. I bought GPU in october 2019. All was super smooth,stable,no issues. I left many games running for hours without crash or restart. But............
Yesterday i left Metro Exodus when i go to work for 12 hours. When i back to home game was still running,fine. But when i click EXIT to main menu,monitor goes black screen and game crashed with display driver crash. After moment and after crash when i was on Windows 10 idle,pc restarted itself ( kernel 41 ). And now its fine again.
My question is GPU OR PSU get overheated ?
I clicked exit to main menu and it crashed to windows with display driver crash.
Second event. After crash i was in Windows 10 and out of the blue, after 2-3 minutes pc just restarted. So why pc restarted itself? PSU ?
ps:
PSU is 2 months old.
Should i worry?
Just simply. After 12 hours i clicked ESC and exit to main menu,it crashed to desktop with driver crash. And after 2-3 minutes system from desktop just restarted out of the blue with Kernel-41.No Bsod.
And now its fine again. Weird?!
One random BSOD is nothing to worry about.
If it starts happening regularly you'll need to do something about it.
Try stress testing the system if you're worried, that can sometimes provoke a response if you've got a bad part.
Hello.
Hello. I think i was get bsod but not sure. System was hanged and lags after crash in game to desktop.
After 1 minute i get system reboot ( like power cut ) and logged to system.
Screen from event log:
20:17:30 reported time of unexpected reboot. There was not bugcheck.
Also found file in : windows/livekernelreports/ pow32kwatchdog.dmp.
Time: 20:18:00
When that happened i dont saw a BLUESCREEN on display,only simply reboot. But my question is. Is that file windows/livekernelreports/ pow32kwatchdog.dmp , was related to that unexpected reboot? Thanks
 My pc rebooted unexpectedly during logging out and logging in to system. It was so fast so i dont saw completely a BSOD. Just like power outage cut. I am not sure if that was BSOD or not.Can somebody help me identify?
Event log said: Kernel 41 event power. No bugcheck.
After reboot i check Windows folder. C:/Windows/MEMORY.dmp not exist. C:/Windows/minidump folder not exist.
Only in C:/ windows/livekernelreports/ pow32kwatchdog.dmp. <--- that file appeared a few moment before reboot.
Thats why i ask. pow32kwatchdog.dmp was a dump from that reboot BSOD ,or it was not BSOD but simply reboot due to for example faulty hardware ( like power cut ) ?
I dont had any problems with stability. All games stable,memtest,realbench all ok.
Thanks for help
PC:
9900K with 32gb ram xmp and 2080 ti , seasonic 850 ultra titanium
  • 2 weeks later...
Hello. My question. Can faulty psu make a BSOD? I mean just BSOD and pc reboot ( without shutdown ). Or not?
Or if psu is faulty then system always shutdown and then reboot.
1 minute ago, worry said:
What code of BSOD?
the codes would be very inconsistent because bad power delivery causes various other components to fail sporadically.
Primary PC:
I left Metro Exodus running by character standing on the same place for 12 hours. When i back to home i press ESC and while exiting from game mission to MAIN MENU ( moment where GPU LOAD drops ) i get BLACK SCREEN and no monitor signal for 1 minute, and crash to desktop with TDR driver crash in event log. After that i log off from system and log back in again and system rebooted unexpected. ( not shutdown but only reboot )
I dont have any other issues with stability in games. It happened once. Thx also not able to reproduce. Very weird.
C:/Windows/minidump ,not exist. C:/Windows/memory.dmp not exist.
Here is screens from dump file ---> C:/Windows/Livekernelreports/pow32Kwatchdog.dmp <--only that file appear. I think it is related to that pc reboot but not sure.
"A callout to Win32k did not return promptly"
https://i.postimg.cc/xCv9gqjd/w1.jpg
https://i.imgur.com/01kGvUb.jpg
It was psue issue or not?
Also my gpu drivers is from november 2019. Windows 10 up to date.
Threads merged
Do not keep posting new threads about the same issue.
