I have a old prebuilt pc that i acquired and i changed the power supply on it to a newer one bc i didnt want it to blow up. Now when i try to boot it up the fans spin up and i hear the hardrive engage but it doesnt post it just sits there lighten up. I also threw out the old psu. I am wondering if i can fix this or is this one of those systems where you cant change any of the components bc of oem stuff or assembler stuff.
https://linustechtips.com/topic/1142017-pc-wont-post/
Are you trying to boot using dedicated gpu or igpu?
You can try some basic troubleshooting first if you didn’t do it yet. Clearing cmos etc
   @Whiro tag or quote will do the trick
Steam Deck OLED 512gb , all other pc’s are gone
                                          WHIRO
         THE FIRST OF DEATH AND DARKNESS
        He feast on the dead to inherit their power
https://linustechtips.com/topic/1142017-pc-wont-post/#findComment-13188354
What are the specs and what is the current rated wattage of the PSU? You probably just plugged something in wrong.
CPU - FX 8350 @ 4.5GHZ GPU - Radeon 5700  Mobo - M5A99FX Pro R2.0 RAM - Crucial Ballistix 16GB @ 1600 PSU - Corsair CX600M CPU Cooler - Hyper 212 EVO Storage - Samsung EVO 250GB, WD Blue 1TB
https://linustechtips.com/topic/1142017-pc-wont-post/#findComment-13188358
