MSI Afterburner Fan Speed and Fan Curve
Solved by Cyberspirit,
The little cogwheel on the left of the fan speed slider activates the user defined fancurve. When it's grey like yours then it's activated. You need both the cogwheel and the auto mode to be on.
Also, there are different skins available in the settings for Afterburner. I personally use the old skin which is a lot simpler.
Featured Topics
aqarwaen29 ·
Posted in Storage Devices7 -
2
IR76 ·
Posted in Phones and Tablets10 -
3
4
SparkFox621 ·
Posted in Troubleshooting0 -
