I am looking to build my first PC. my budget is not crazy, so I'm not looking for the most insane features or anything like that.
I plan on putting in a Ryzen 5 3600 and an RX 570.
Which motherboard would be best for around this budget (RGB doesn't matter, WIFI is nice)?
-MSI B450 Gaming PRO Carbon AC
-ASUS ROG Strix B450-F Gaming Motherboard
-GIGABYTE X570 Gaming X
https://linustechtips.com/topic/1140721-help-which-motherboard/
this is the most appealing one out of the 3 to me, unless you can also get the Asus X570-P
Desktop benching:
https://linustechtips.com/topic/1140721-help-which-motherboard/#findComment-13177878
4 minutes ago, TechnoBro03 said:
So you would recommend the Asus X570-P over all of those 3?
Apart from the lacking rear I/O and wireless, yes.
Desktop benching:
https://linustechtips.com/topic/1140721-help-which-motherboard/#findComment-13177984
1 minute ago, TechnoBro03 said:
I heard the VRM cooling was not very good on this motherboard, any thoughts? And why this one over the MSI B450?
Not at all. This VRM has really good cooling, overall performance is even better than the MSI B450. Also the non Max boards dont have enough BIOS chip capacity for a good looking interface, so it's UEFI doesn't look as good as MSI's typical BIOS
Desktop benching:
https://linustechtips.com/topic/1140721-help-which-motherboard/#findComment-13178007
