Hello fellow gamers...i took my gpu out to clean pc but when i put the gpu back in there is no display through gpu, only through integrated graphics...i have a asus rog strix gtx 1060....here is what i tried so far cleaning the pci-e...reseating the ram connecting through both hdmi and dvi and disabling intel hd graphics...
Pls help someone i am really worried here...
https://linustechtips.com/topic/1140596-need-help/
did you try display port 1.4/1.2
also is it properly seeted? on the pcie slot
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1140596-need-help/#findComment-13176960
